Inj.pump Code
Inj.pump Code
I HAD MY LIFT PUMP CHANGED UNDER WARRANTY 1 WEEK AGO,THE INJ.PUMP CODED P-0216 ALSO,HOWEVER THEY TOLD ME THAT SINCE I HAD AN EDGE CHIP THAT IT MIGHT NOT BE WARRANTABLE.ARE THEY BLOWING SMOKE OR AM I SOL
Probably, depending on the Dealer, most won't honor a warranty with any mods whatsoever. Mine told me any mod was ok except injectors, but I know the Service Advisor. Does it run ok?? Try resetting the codes and see what happens.
Tom
Tom
THANKS FOR THE REPLYS.THE CHIP IS A PLUG IN UNIT I GOT IT FROM A FRIEND WHO USED TO WORK AT THE DODGE DEALERSHIP IN ACCESSORIES DEPT.HE TOOK IT OFF A CUSTOMERS TRUCK AND GAVE IT TO ME.THE INFO ON THE BOX IS UNREADABLE SO AM GOING BY WHAT HE SAID.THIS MY 1ST DIESEL HAS 65000 MI.I'VE HAD THE TRUCK FOR A LITTLE OVER A YEAR......02 EXT.CAB SHORT BED HO 6SPD 3.55 LSD
Chipped DC
The lift pumps and injector pumps have been a major disaster for DC and DC is doing everything it can to avoid paying for the repair. I'm in the same boat as you, the dealer changed the LP under warranty but when it came to the injector pump they said no way because it's chipped. We all know it has nothing to do with the chip but has all to do with the LP failure. When the LP fails the injector pump has to pull from the tank and it's not designed to do that. Not long after the lift pump goes the injector pump.
If you can remove ALL traces, and I mean ALL traces of the EZ unit you might be able to take it to another dealer and have it done under warranty. Apparently they don't pass the information onto DC so it might be worth a try.
camerd18
Aug 21, 2008 07:20 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
