idle speed
Old Dec 18, 2002 | 10:32 AM
CandSRanch's Avatar
idle speed
My truck's idle speed has varied greatly lately. It usually idles around 800 rpms, but on certain occasions it has run as high as 1100 rpms. This is after the truck has heated up and been driven for a while. The truck has only 3000 miles on it and my fuel mileage has dropped lately(shouldn't have winter blend fuel in southern Oklahoma). What is the standard idle speed and what could be the reason for this problem? Thanks in advance.
Old Dec 18, 2002 | 01:52 PM
P Kennedy's Avatar
Re:idle speed
Possibility that you have developed an air leak in the fuel lines or system, do any changes lately to the fuel system. Check out any diesel leaks on engine.PK
Old Dec 19, 2002 | 03:22 PM
Santa Feh's Avatar
Re:idle speed
First, this isn't the cold weather fast-idle feature kicking in, is it? <br><br>If not, the high idle is probably due to a bad sensor. Either the APPS/TPS (accelerator pedal position sensor/throttle position sensor) is (in error) telling the ECM that you're pressing the accelerator when you're not, or the sensor that the ECM uses to detect engine speed is not working properly. I'd check the APPS first.
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
