idle problem
Old May 30, 2007 | 11:43 PM
MATTIEBOB's Avatar
idle problem
in the morning when i start my truck it surges at an idle til it start to warm up. it only seems like it does it after it has set for at least 8 hrs. no rpm change on the tach and the only codes are p0234 & p1693 any help would be greatly appreciated.
Old Jun 1, 2007 | 04:44 PM
2RamsNoCash's Avatar
sounds like air when my lift pump started acting up I had similar issues.at times when I let it sit for days during our heavy snows it took alot to start and would stall when I got running and warmed up was fine.new lift pump from napa cured it all till next time then its a FASS.
Old Jun 2, 2007 | 03:47 PM
MATTIEBOB's Avatar
thanks alot for the info i will check the lift pump. i know the fuel pressure is good when warm, it is about 15psi at idle and 10psi at 3000rpm. so im sure it is something simple
freds89
May 7, 2009 08:54 PM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
