identifying a bad clutch
Old Nov 9, 2007 | 05:03 PM
darrenG's Avatar
So, couple days back I posted about possibly needing to R/R my trans but the more I think about it the more I think part of the problem is the clutch. I was getting stuck in the occasional gear and sometimes it wouldn't go into gear without matching the RPMs.
I just towed ~6k lbs up to Fordyce last weekend and back down and I had 0 clutch slippage. Aside from slipping what other symptoms does a dying clutch exhibit? What should I be looking / listening / feeling for?
Old Nov 9, 2007 | 09:56 PM
need12v's Avatar
if it wont disengage the clutch it sounds like a hydraulic problem. Either the slave or master cylinder is shot or the fluid is low.
Old Nov 10, 2007 | 07:08 PM
darrenG's Avatar
So, the two symptoms of a dying clutch are it's either slipping or won't disengage? That's what I figured but felt i'd run it by the masters.
Old Nov 10, 2007 | 09:42 PM
need12v's Avatar
Not disengaging is not an indicator of clutch condition, it just says the hydraulic release is not working properly
powerrammaster
Oct 19, 2007 01:44 AM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
Turbo Deeezle
Dec 2, 2004 09:01 PM
