Code 0122
Old Nov 9, 2007 | 06:23 AM
1BAD4X4's Avatar
Code 0122
Check for codes and 0122, along with 1693 came up... anybody by chance now what it means?
Old Nov 9, 2007 | 06:31 AM
danimal1208's Avatar
Try - P0122 Throttle Position Sensor/Switch A Circuit Low Input; and P1693 Turbo Charge Control Circuit Malfunction.
Old Nov 9, 2007 | 07:25 AM
J Lent's Avatar
Have you disconnected your battery?
Old Nov 9, 2007 | 08:52 AM
graphitecumnz's Avatar
may or may not cause driveability issues... there are some reset procedures for this. One can be found here in the tech facts and I think the other is put out by DTT... don't quote me on that though. Either of these may only be a temporary fix but if you're not noticing driveability issues... dead pedaling, bucking and jerking at low RPM... you may not even have a real problem yet.
Old Nov 10, 2007 | 03:15 PM
1BAD4X4's Avatar
The APPS was loose because I removed that to tap the VP44, so I'm sure thats where the 0122 came from. Think the tap caused the 1693?
No I haven't disconnected the battery.
Old Nov 10, 2007 | 05:35 PM
wurkenman's Avatar
Correct me if I'm wrong, but isn't p1693 just a companion code?
Old Nov 10, 2007 | 06:35 PM
1BAD4X4's Avatar
Thats what I thought too... I had it come up with a different code a few months back... and thats what somebody on here said.
Old Nov 10, 2007 | 10:24 PM
J Lent's Avatar
Yes it is a companion code. The 0122 is the trouble code.
Paws
Jan 5, 2010 01:57 PM
ropem24
0
May 22, 2007 09:11 PM
DISTURBED
Oct 7, 2006 12:07 PM
