IAT Sensor
Old Oct 19, 2007 | 09:45 PM
scout98's Avatar
IAT Sensor
When removing my head I did not see the IAT sensor and pulled the wires from the plug well I put them back in the only way they would go.
So now on start up I now have a P0113 code that I can not clear have re-checked the wires in the connector and they look good. is there a way to check the sensor like with an ohms meter? or check the wiring to see if it is good?
Old Oct 20, 2007 | 09:47 AM
clarson80's Avatar
I'd just get new one, they aren't really $$$, then you know for sure it's working correctly.
Old Oct 20, 2007 | 11:36 AM
Dr. Evil's Avatar
Have a look here:
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
Old Oct 20, 2007 | 12:24 PM
scout98's Avatar
Thanks Dr. Evil
I do plan on replacing the sensor but since I messed up the plug I did not want to go get a new one and mess it up or not fix my problem.
I did see on another thread where the input voltage from the ECM is suppost to be 12V.
Old Oct 20, 2007 | 05:47 PM
scout98's Avatar
Well got it fixed
My plug was not getting a good connection P0113 code cleared
Now I need to find out if new plugs can be purchased to replace the one on my harness
Old Oct 21, 2007 | 12:04 AM
Kennys's Avatar
Don't think that you can buy them without buying a harness. If you can't find one, I have an old harness that I can take one from.
scottboy69358
Jul 4, 2013 02:05 AM
supr
18
May 21, 2007 09:29 AM
Shepherd57
May 5, 2003 05:04 AM
TX Ram
Feb 26, 2003 10:38 PM
bkay
Jan 17, 2003 03:30 PM
