Hydraulic oil in transmission
Old Aug 1, 2007 | 11:37 PM
bazdad's Avatar
In the General Information section it states to get better lubrication in the transmission to use either synthetic oil or hydraulic oil. Is any one running hydraulic oil instead of transmission oil?
Old Aug 1, 2007 | 11:45 PM
oldblues's Avatar
hi
i believe the atf+4 is a synthetic , i use the wallmart brand !
maby you could use the hydraulic tractor trans fluid , but i dont know whitch type ?
Old Aug 2, 2007 | 07:02 AM
gmctd's Avatar
Hydraulic oil doesn't have additives to protect the electricals, the plastics, the clutch-packs, and the seals in modern automotive automatic transmissions - I'd stick with ATF in syn or standard, or as your rebuilder suggests - f'rinstance, call Dave Goerand, go with what he suggests
Also, don't use ATF in your power steering\hydroboost system - the seals are not compatible, and will soon leak
Old Aug 2, 2007 | 10:18 AM
bazdad's Avatar
Thanks for your reply. I did not think that was a solution. How often do we change the synthetic transmission oil?
Old Aug 2, 2007 | 05:45 PM
Fishin2Deep4U's Avatar
I agree with not using hydraulic in the trans. It's fine for race cars, but little else.
Synthetic should be changed in the same intervals as dino. It resists shearing and thermal breakdown, but it will eventually become contaminated from the cluth materials ect in the trans.
I use the cheap stuff and change it often.
Dave
Old Aug 2, 2007 | 07:01 PM
DryCreek's Avatar
Wait,
are we talkin' manual or standard transmissions here?
The NV4500 requires synthetic, period (and GL-4 to boot!)
The auto's all require ATF+3 or +4, depending on year. This is a synthetic.
The NV5600 uses Pennzoil Synchromesh, which I think is a dino oil, but can't get a definitive answer on.
The G56 uses ATF+4.
Dry Creek
dodgetrucker75
Aug 5, 2012 04:32 PM
West Coast
Jul 25, 2008 12:27 AM
BC847
May 11, 2008 12:01 PM
CMooreBLKSMK
13
May 7, 2008 03:03 PM
6cylinders
Mar 26, 2007 07:31 PM
