hub bearings stuck, everything else bad
Old Sep 3, 2012 | 11:32 AM
stationarycoppe's Avatar
Took the old beast into get aligned only to find out the 3 of 4 ball joints are bad. Started to tear into it yesterday to find a bad U-joint, an axle seal leaking and a questionable hub bearing.
I can not get the hub bearings out on either side. I am to the point that I don't care about the bearings since one was bad anyways. I have tried hitting the bolts with a hammer, the power steering trick, and I even hit the wheel hub with a sledge since it looked like someone already had tried that. I am in day two of soaking them every couple hours in PBR blaster with no luck at all. Anyone got any other ideas? I really need this thing back together for work this week if possible.
Thanks
2002 2500 4x4 FYI
Old Sep 3, 2012 | 01:33 PM
ehohn's Avatar
10 Year Member
did you get the hub bearing out yet ,i tried all of the same things and use a torch they are rusted in place, you must replace them , got mine at napa $245 each. clean the yolks and antiseize
Old Sep 3, 2012 | 03:24 PM
I hate to take a torch to the knuckles especially after the amount of PBR blaster I have sprayed on them. Amazon has the oreily's brand bearings for 158 and timkens for 201. BUT that doesn't help me right now since I still can not get either side.
Old Sep 3, 2012 | 06:10 PM
slim51015's Avatar
I had that happen a couple times. I took my 4" grinder with a cut-off wheel and made a slice between the spindle and the hub bearing at two opposite corners where the bolts come through. Make the cuts pretty deep. That will give you a spot to start a chisel in and wedge it out by driving the chisel in. start with small chisel that doesn't taper much.
Old Sep 3, 2012 | 06:37 PM
gorms's Avatar
I dunno, when it glows it goes in my book. I had one really stubborn one in my old 1500 that I borrowed an acetelene torch for. Nice even heat, cooled the bearing with a wet rag and it practically fell out, wasn't quite glowing but pretty close. 2 days before that trying to pound in chisels, soaking in PB, power steering tricks, you name it. Good luck, these front ends suck sometimes to get apart.
sluggo42
Jan 30, 2011 01:48 PM
xxwildbillxx
Dec 8, 2010 11:01 PM
Rafter B
Jan 11, 2009 08:40 PM
Justinlhc
Nov 9, 2008 02:06 PM
Baja
Jan 29, 2008 08:17 PM
