How To Properly Start Truck After Fuel Filter Change Etc.
Old Jun 16, 2006 | 07:42 PM
Ridiculous's Avatar
i was just wondering the proper way to start one's truck after replacing the fuel filter, or perhaps installing a FP guage. i've done both and both times the truck did not fire up right away.
for my fuel filter, it did fire up but then died, so i was told by a buddy of mine that i need to crack a couple of the injectors and bump the starter about 6 times and then just crank it.
for the fuel pressure guage, i tapped into the bottom of my fuel filter canister and when i was all done, the truck did not wanna start, but this time, i just bumped the starter, waited for the pump to run, repeat several times and just crank it, then she finally fired, but i got a lot of white smoke for quite a while.
so what is the proper procedure for restarting the truck when something like this happens, or when one runs out of fuel for example?
just curious and bored so i decided to start an online conversation
Old Jun 16, 2006 | 08:49 PM
Truckman's Avatar
Thumbs up Do A Search
If you do a search on this site you would find this ,,
https://www.dieseltruckresource.com/...d.php?t=101881
Instead of us typing it again ,, hahahahah
They talk of 1998.5 - 2001 I think..
Hope it helps.
Old Jun 17, 2006 | 12:25 AM
Clunk's Avatar
Thumbs up
After draining and changing the filter & gasket, I fill mine 3/4 full of clean fuel, screw on the top w/new filter then bump the starter 4 times to prime the system then start the engine. A little fuel might leak out while screwing the top on but the fuel filter housing is now full of fuel...I haven't had to crack open an injector line yet.
That tube standing in the middle is the fuel filter outlet tube and the fuel level needs to be higher than the hole in that tube or you'll be trying to push air through the injector pump before it'll start.
Old Jun 17, 2006 | 12:43 PM
Puke's Avatar
Every time I do it the same thing happens.
1) change the fuel filter.
2) leave a plug in the top of the filter houseing loose and bump the starter.
3) diesel fills it up and squirts out the side so you "know" it;'s full of diesel. so you tighten the plug back in.
4) now try to start it and it fails.
5) loosen an injector (in my case the front one cause I'm lazy and it's closest
6) crank the starter again
7) tghis time after some cranking it starts with a little missing at first, but then I tighten the injuector back up and all is back to normal, waiting for another few months to do it all over again.
The first time it was kind of alarming, but from then on, it was expected and just a few minutes process. A farm boy (they had a lot of diesel tractors on their farms) who worked for me showed me this the first time around (after I got real scared I was going to need a tow), but after that I did it myself.
OK<
Just my two cents worth.
Old Jun 17, 2006 | 01:20 PM
Patrick Campbell's Avatar
I dont know if 98's do this but I will change the filter, bump the starter so it fills the fuel bowl, and then start the truck.
Old Jun 17, 2006 | 05:18 PM
Ridiculous's Avatar
thanks guys, i was doing it right the whole time, just curious
440FURY
Jun 11, 2006 08:12 PM
steverctx
21
Nov 18, 2005 07:45 PM
Ian
Oct 5, 2005 05:40 PM
jlells01
Sep 1, 2004 08:42 PM
sjester
Aug 1, 2004 07:50 PM
