how much is truck with cracked block worth?
Old Mar 16, 2010 | 12:33 AM
nelly's Avatar
Whats a 1999 xtra cab 4x4 shortbox auto truck with only 175,000kms worth? Its in descent shape with SLT Laramie trim. Is It worth metal stitching?
thanks,
Doug
Old Mar 16, 2010 | 01:03 AM
dodge24's Avatar
I wouldn't bother with trying to repair that block. It will crack again and it will crack worse than it did the first time. The money you would spend on Lock and Stitch would go a long ways toward a replacement block. You can find used 24v for between $1000 and $3000 from what I have been able to find. Good luck!
Old Mar 16, 2010 | 07:43 AM
patdaly's Avatar
Agreed, cheaper to do it right the first time.
The basic problem is, the truck is really worth more parted out than together ( assuming work is done at close to fair market value )
Thus, the trucks real value as a driver is stupid low, say 1500-2000. The problem with that analogy is you can get far more than that parting it out, so the obvious thing is to part it out.
Without seeing it, around here that truck would bring 6500-8000 depending on condition. If you can drop in your own engine, and have time to wait until you find a fair deal on an engine, I would say you could swing as much as 4K, which is more than it is worth parting out.
Old Mar 16, 2010 | 06:40 PM
lvmknsmoke..'s Avatar
i have mine in the shop getting a 01 motor with a low for me 150k on it. my block cracked an i had a guy weld it for me and it held and only seeped a little. but yes for a long term solution def get a diff short block or whole new engine.
Old Mar 17, 2010 | 12:01 AM
nelly's Avatar
I could buy the truck for $4,000...hmmmm
Old Mar 17, 2010 | 12:50 AM
dozer12216's Avatar
TOOOOOO much!!!!! OPS, I see from Canada. The rules for you all seem different. Perhaps a different approach for truck. Really need to get price down under 3000 (I forget the exchange rate and value in BC.) Now if can find a used engine for reasonable price of say 2K you would be in good shape. This assumes body and rest of drive train are in good to excellent condition. Condition is a make or break on deal!!!!!!
klx650a2
Apr 20, 2009 05:25 PM
roughstock
Jan 27, 2008 10:37 PM
OldSmokey
Apr 2, 2005 10:57 PM
patriot pearl blue
Nov 18, 2003 11:03 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
