How high are your RPMs at 70mph?
Old Jul 31, 2007 | 10:24 PM
  #31
jrs_dodge_diesel's Avatar
Originally Posted by JyRO
3.54's here ... and a 6 speed. Mine's right at 2,100 to 2,125 rpm at 70 mph in 6th gear. It's hard to say the rpm, because the tick mark intervals are stupid. 2,000 - 2,125 - 2,250 - 2,375 - 2,500 Instead of even 100 rpm increments! At least that's how it is on 2nd gen trucks.
I hear you on that one. I don't like the 125 RPM tick mark intervals either.
Anyway, at 70 MPH I'm at ~1,800 RPMs. My truck has 3.55's and an auto.
Old Aug 1, 2007 | 01:03 AM
  #32
1BAD4X4's Avatar
Thanks HOHN for the clarification!
Old Aug 1, 2007 | 08:14 AM
  #33
JyRO's Avatar
I was a bit off, 70 mph in mine is right at 2,000 rpm. Stock size tires, 6 speed and 3.545454545454545454545 gears.
I left off a few digits, so the gear ratio wouldn't be so inconvenient to look at.
Old Aug 1, 2007 | 11:27 AM
  #34
Dinner's Avatar
Hmm if some of you fellas are running around 1800 RPM with 3.55 gears(even though they are suppose to be the same). Would that mean us guys that say we have 3.55 by the sticker are running 2000RPM would actually have 3.54 gears?
Old Aug 1, 2007 | 12:04 PM
  #35
JyRO's Avatar
No. The lower rpm guys are auto, the higher are manuals.
Old Aug 1, 2007 | 12:29 PM
  #36
R.T.D.H.S.P.'s Avatar
2200 at 70mph (4.10s). A little less on cruise.
Old Aug 1, 2007 | 01:17 PM
  #37
RowJ's Avatar
They are 5 speeds only. Top gear on the 6 speeds is very, very close to the .69 ratio on automatic Overdrive.
Biggest difference in the rpm's is in the 35" tires!
RJ
Old Aug 1, 2007 | 01:26 PM
  #38
CrashCade's Avatar
Shoot, I am at about 1750 or so at 70mph. 3.73 37"
Old Aug 1, 2007 | 01:48 PM
  #39
signature600's Avatar
RJ
Actually RJ, the NV5600 is .73 in 6th, the NV4500 is .75 in 5th, and the Auto's are .69 in 4th...technically, the two manuals are closer to each other than the auto. (Chris = PITA)
I've had all 3 tranny's in both of my trucks (had NV4500, and NV5600 in my 95, and auto in the 98, both 3.55's)
The 5spd was about 70mph at 2000, the 6spd is about 1900RPM at 70mph, and the Auto is 1825 at 70mph...all 235/85R16 Tires!
I just took off my 35" 19.5's and the Auto and "laggy" charger is MUCH happier spinning the 235/85R16's. Cruising RPM went up about 150RPM, and it is a whole lot more responsive...of course my 19.5's weighed about 140lb each vs. 40-50lb 235's!
Chris
Old Aug 1, 2007 | 01:49 PM
  #40
HOHN's Avatar
RJ
.73 vs .69 to be exact
5-speeds are .75
Old Aug 1, 2007 | 01:58 PM
  #41
Southern Pride's Avatar
75mph 2000rpm. 70mph, 1850 or whatever the "awesome" tach says
steve21
Sep 12, 2008 12:34 PM
kyle_truck_pull
Apr 8, 2008 07:53 PM
Teddy Bear
May 1, 2006 08:15 PM
iwannaram
24
Dec 20, 2002 11:56 PM
