How do you tell what rear end you have?
Howdy,
I am trying to find out what rear end type I have. I guess it doesnt matter cause what ever it is it works great, but I hear so much about them. Is it writen somewhere?
Thanks, Nimrod
Thanks, Nimrod
There should be a sticker in your glove box that shows the gear ratio. It may also tell you if you have a limited slip diff or not also. If you still have it, all that info will be on the original window sticker too.
If worse comes to worse, you can get your DC dealer to print you a line setting ticket at the parts counter for free. They'll need your Vin. It will show what came from the factory
Frank.
Frank.
If all else fails jack up the rearend and mark the tire to a specific place, mark the driveshaft at a reference point as well. 4.1 turns of driveshaft per 1 turn of wheel= 4.10 3.5 turns of driveshaft per 1 turn of wheel= 3.55. If one side jacked up won't turn and both sides have to be off ground LSD rearend. PK
Nimrod,
I think all the 03's and 04's have 3.73 rear ends. In 03 Dodge went away from the Dana differentials to a differential that Dodge produces. From all accounts the new rear ends and front differentials are holding up fine. I think 3.73 is correct.
Meacham Evins
Meacham Evins
To tell what rear end you have, first set up two mirrors. Stand in between and look closely. This is subject to personal taste.
For a subjective perspective, post picture on rate_my_rear_dot_com.
Dave
Dave
Howdy,
Yep you are right, in the glove box there is a list of gear ratios. My truck has a 3.73 rear gear ratio. Well now I can sleep at night and I know the truck will drive better kinda like it does after I wash it. This is a ratio that seems to work all around. I wonder what my 93 Dodge had because it always seemed to be perfect for towing a big load and got incredible fuel econo. Put new sheepskin seat covers on her that I got for Christmas from my Wife. Now the cloth is protected and it is sooo comfy.
Thanks for your help on my rear end.
Nimrod
Nimrod
JonathanFleguel
Sep 21, 2010 11:11 AM
samasaurus
Jan 17, 2007 08:12 PM
Patrick Campbell
22
Dec 3, 2003 04:45 PM
