How do i tell what rear end i have
I'd hazard to guess a Dana 60 w. 3.54's. There should be a sticker under the hood that has the specs, right where the latch is. It may also be stamped/cast into the rear end housing.
its incredibly hard to read but this is all i can see it would appear to be limited slip which would make sense sinse it will roast both tires. i dont know if this helps any
"rear axle spider 70 limited slip"
Commonly referred to as a Dana 70. Nice! You'll have a hard time destroying that bad boy.
I'm no expert, but I think us 'D' truck owners have the LSD, the 'W's have a full locker.
Actually, that may have come off a 350, I didn't think they put 70's on 250's stock. Not sure on that, hopefully someone will clarify.
I'm no expert, but I think us 'D' truck owners have the LSD, the 'W's have a full locker. Actually, that may have come off a 350, I didn't think they put 70's on 250's stock. Not sure on that, hopefully someone will clarify.
Some specs and info for ya.
Ring gear measures 10.5".
3.5" diameter axle tube.
Inner axle shaft spline counts are 23, 32, and 35
Pinion shaft diameter: 1.75"
Pinion shaft splines: 10 and 29
Gear ratios: 3.07:1 - 7.17:1
Axle Shaft diameter
1.50” Rear (35 Spline)
Axle spline diameter
1480 Universal Joint (Front axle)
All Dana 70 rear axles are full floating. The Dana 70 rear axle was first used in the Dodge W300 in 1957. The Dana 70 started out using 10 spline pinions and 23 spline axle shafts. The later, more current, Dana 70 axles use 29 spline pinions and 32 or 35 spline axle shafts. Dana offered two different limited slip differentials with the Dana 70, the "Power-Lok" and the "Trac-Lok."
Axle Shaft diameter
