Here's one for you brake guys
Old Jul 1, 2006 | 05:05 PM
BigBlue's Avatar
At 100,000.0 miles my ABS and brake light came on and have stayed on now for the last 3,000 miles. I've lost all ABS control (which ain't neccesarily a bad thing). A couple of times before this happened whenever I'd press the brake pedal very lightly the pedal would sorta pulsate all the way to the floor and the lights would come on and then they'd go off in a day or so. I tried pulling the fuses and all that happens in my ABS light goes off but my brake light stays on. I tried scanning it with my smarty and there are no ABS codes and I'm not about to take it to the dealer for $90 to have them do it. Tach and speedo still work, rear speed sensor is only 4 months old and driver's side front ABS sensor is about the same (had to replace the hub so I swapped the sensor). Whenever I start the truck the brake just stays on no matter what but the ABS light turns off and then turns back on. I've tried unplugging the batteries, disconnectin the wiring harness from the ABS box. I'm at my wits end. I hate seeing those lights on cause it's tacky, annoying, and I would like to have my ABS back on certain occasions. Thanks for the help yall.
Old Jul 1, 2006 | 05:44 PM
Geico266's Avatar
A piece of black tape at just the right angle and you are good to go.
Old Jul 1, 2006 | 05:57 PM
BigBlue's Avatar
It's getting to that point but I'd rather fix stuff the right way if possible. I hate knowing I have lights on and something on my truck is broke. It bothers me.
Old Jul 1, 2006 | 07:11 PM
RickCJ's Avatar
Usually the rear speed sensor!
Old Jul 1, 2006 | 08:03 PM
Lt.B's Avatar
Have you checked the fluid level in the master cyl.?
Old Jul 1, 2006 | 09:58 PM
Dieseldude4x4's Avatar
Both lights have been on for about three years now. Dodge machine reports "RF wheel sensor open". Doesn't bother me a bit since I hate ALB's anyway.
DD4X4's saying of the week: "the smarter cars get, the dumber people get".
I learned to drive in a 49 Studebaker dump truck. I still have an 81 Dodge truck slant six (pic in album) with power nothing on it and love it. Wake up people and learn to drive drive.
Whoa, did I get off topic there? SLAP !!!!!!
OK, back to the topic. Something tells me you have to pretty much disassemble the entire front wheel hub to replace that switch and I ain't ready for that yet. 172,000 miles and the front brakes are still original and over half there. Gonna be a while I guess.
Old Jul 1, 2006 | 10:30 PM
BigBlue's Avatar
I'm not sure on yours but on mine all you have to do to get to the sensor is remove the rotor and then it's just 2 little bolts holding it on. Trace the wire and unplug it. How in the world do you still have half of your brakes left? I'm on my 5th set.
Old Jul 1, 2006 | 11:11 PM
dodgetech77's Avatar
The last time i saw that problem the trac lock came apart in the rear diff and chipped a tooth on the tone ring
Old Jul 1, 2006 | 11:16 PM
BigBlue's Avatar
Thankfully that ain't my problem. I just changed the fluid in my axles and the tone ring was in good shape. I guess I'll go and warranty the rear sensor and see if that fixes it. Any other ideas yall?
Old Jul 2, 2006 | 12:27 AM
high country's Avatar
what codes did it puke at ya?
Old Jul 2, 2006 | 01:23 AM
BigBlue's Avatar
Not a single flipping one. The on-off key trick nor the smarty pulled any.
Old Jul 5, 2006 | 02:54 PM
BigBlue's Avatar
Changed the rear speed sensor out and it didn't do anything. It flashed the lights on and off and then they came right back on. Any other ideas yall?
Old Jul 6, 2006 | 08:19 AM
BigBlue's Avatar
Anyone? TTT
Old Jul 6, 2006 | 06:10 PM
Jacobs since about 15000 miles and careful driving. I pull up to 26000 pounds too on occasion. I gotta pull them in the next week or two to clean and lube the caliper slides. I'll get some pics of the pads when I pull the calipers off.
Old Jul 6, 2006 | 07:35 PM
storx's Avatar
pulsing of the brakes is the master cylinder and if anything is wrong hydraulicly....the abs should be nothing but a valve box and electrical sensors to electrically pulse the brakes on you when you slam on them... If the brakes are working then your master cylinder is working if you press on the brakes does it go all the way to the floor if it does then you have bas MC if not its something in the ABS circuit... Im to bet its one f the sensors on teh front....
