help it won't start??????
Old Apr 18, 2003 | 05:51 PM
Rampuller's Avatar
Hi Guys<br><br>My 2001 ( Rampuller mentioned this in last post) 24 Has a problem. I lost the oil pressure so I started trying to find the sensor.( I have since found it)<br><br>Now The map sensor got unpluged and I started the truck. It would start but the check engine was on ( wait to start light works okay) but I have no gauage function and the engine goes to high idle mode. I depress the throttle and the engine speed drops and the truck appears to miss. The truck will not rev up ( tach not working so I have no idle speed)<br> I plug the map sensor in and the check engine light goes off but when I Try to start it just turns over and over. ( the wait to start light flashes when the key is on)<br><br>One other thing is that none of the gauges work at any time and the oil pressure is way to high when the truck is running <br>I think I need to reset the computer. How can I do this? Is it just stuck in limp mode? <br><br>2000 ctd 24 valve 5 spd<br><br>Thanks
Old Apr 19, 2003 | 10:59 AM
Stamey's Avatar
Re:help it won't start??????
I suggest you try resetting the APPS. The procedure is in the tech section. <br>http://www.dodge-diesel.org/faq/faq....p;onlynewfaq=1<br><br>When unhooking the battery, you might want to leave it unhooked for an hour, and leave somehting on, such as ignition to drain caps in the system.<br><br>The unhooking of the battery may also clear some of the codes the disconnected MAP sensor set, depending on what computer the codes were set it. I think the ECM keeps them until Cummins resets them.<br><br>Chris
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
