Help..truck quit
Help..truck quit
My buddy just bought me his 1999 5 spd 2WD truck and said it quit after leaving a stop sign and going into 3rd gear made a POP sound and died. wont start anymore.
The only code is P1688.
I think that is injection pump related but that doesn't explain the POP he said he heard.
This thing will not stat and run at all.
Any suggestions?
Any suggestions?
The pop he heard could have been the effect of altered pump timing, delivering fuel at just the right time to cause a backfire, or perhaps a late shot that went out the exhaust.
P1688 is a death code for the pump. Period. See that one, and the rodeo is over.
Good luck with it
Good luck with it
With everything being new I would check the connection(electrical) on everything, also I would make sure you are getting fuel to the IP, if you bump the start you should hear the lift pump run, if you don't you need to check the relay on the fire wall. Its the on that goes to the small grey connect that use to connect to the LP on the side of the block. After you know the fuel pump runs, then I would make sure fuel is getting to the IP, crack the line on the side of the IP and bump the start, you should have fuel everywhere. After that, I would crack a few injector lines and see if you get fuel at the injectors, you should get alot of fuel after a few second of cranking.
silverram323
Oct 20, 2003 01:04 PM
MoParr
0
Feb 16, 2003 01:26 AM
