Help! Something seriously wrong
Old Jun 9, 2003 | 08:25 PM
  #33
Haulin_in_Dixie's Avatar
Re:Help! Something seriously wrong
[quote author=Jack Thorpe link=board=4;threadid=15586;start=15#147415 date=1055180794]<br>[quote author=Haulin in Dixie link=board=4;threadid=15586;start=15#147408 date=1055179473]<br>[/quote]<br><br>Funny thing is that I just got done calling around to parts stores, and there is only ONE store that I could find that has crush washers. They only have the copper ones.<br>[/quote]<br><br>The only source that I have found is Cummins. If you don't have a cummins dealer around you I can drop a few in the mail for you. If you need them just let me know.
Old Jun 9, 2003 | 08:46 PM
  #34
StakeMan's Avatar
Pusher pumps won't push through the stock lift pump.
Old Jun 9, 2003 | 09:12 PM
  #35
Stamey's Avatar
[quote author=StakeMan link=board=4;threadid=15586;start=30#147572 date=1055209603]<br>Pusher pumps won't push through the stock lift pump.<br>[/quote]<br><br>I always wondered about that. I have ahd a situation where I was able to draw fuel through the stock electric in-tank fuel pump for an 86 Ford. I put the tank in my 82 Ford and the stock mechanical fuel pump actually sucks fuel through it. I think this was just a fluke though, because it's really rare to get th epump rotor to line up perfectly to allow flow through, if it's even possible.<br><br>Jack, since the pusher pump won't help if the main goes out, you might consider a bypass deal like I did. If my Holley Blue ever fails I can actually go back to the old fuel system by installing one banjo bolt, and replacing the fuel line at the tank.<br>This is how I did mine, if you want ideas.<br>http://www.Stamey.nu/Truck/FuelPump.htm<br><br>Chris
Old Jun 9, 2003 | 11:56 PM
  #36
AlpineRAM's Avatar
Stamey: I had a pusher pump setup for some time nad the pusher worked for me- even when the stock pump failed I had a little positive pressure up to WOT on the pusher alone. Fuel can get through a rotary vane pump because if the pump motor is stopped the vanes are not forced towards the outside. <br><br>Jack: I've got a Holley Blue on the frame rail- works for me. <br><br>AlpineRAM
Old Jun 10, 2003 | 12:27 AM
  #37
StakeMan's Avatar
Not if the pump is plugged with debris.
Old Jun 10, 2003 | 01:28 AM
  #38
AlpineRAM's Avatar
StakeMan: That's correct-but if you plug any crucial part in any system you won't have flow ....<br><br>AlpineRAM
Old Jun 10, 2003 | 04:42 PM
  #39
BigBlue's Avatar
I like my Holley Black. 19 psi at idle and 13 at WOT with pump wire.
Old Jun 10, 2003 | 09:39 PM
  #41
TPilaske's Avatar
Very interesting.... guess I won't be looking into a pusher anytime soon! Glad you got your issues resolved! ;D<br><br><br>Tony
Old Jun 11, 2003 | 09:15 AM
  #42
Dieseldude4x4's Avatar
I was considering the larger pick up tube that Banshee had and mounting two stock pumps back at the tank. Haven't figured out what else I want to do yet. Maybe a 1, 2 or both pump set up switch too.
Old Jul 10, 2003 | 12:25 AM
  #43
KwikKurt's Avatar
For what it's worth..... This is what I do. I install a Carter <br>15PSI 100GPH Pump that is very similar to our stock lift pumps.<br><br>It is mounted to the outside of the frame next to the Fuel tank. Then Just hook a Hose from the pump to the tank outlet after unhooking the oem suction line to the lift pump. Then I run a High quality fuel rated Hose to the inlet side of the filter on the engine. Wiring is done by running 14 gauge wires from the stock pump harness by &quot;T&quot; taping after it is unplugged from the oem pump. <br><br>The end result is Reliable OEM fuel pressure. IF the pump fails you pull in to a Napa store and change it right in the parking lot with a Pair of plyers and a screw driver.<br><br>Benefits of this system. <br><br>1. Inexpensive $125 (Pump) or Less for a Pump that delivers Stock level pressures with High Horse Power Flow rate.<br><br>2. Easy to Find! (Napa) <br><br>3. Easy to change. less than ten minutes.<br><br>4. Will it Deliver enough fuel???? With a Drag Comp and Don M's Mach 6.5 Injectors (150-170?+ HP) Pressures are above 7psi-10psi at WOT. and 13-15 at idle.<br><br>5.It's actually a ready made backup system. If you need too simply hook up your stock line at the tank. (EASY!). Then hook the front line back to the filter inlet. Then PLug back in the OEM Pump's connector and then it's stock for your trip back to the dealer.<br><br>MORE Info. Our stock Carter pumps are good BUT They Hate the Long Suck from the Tank. One Example is on my customers trucks that always have full tanks maybe with a Extra tank in the BED. Lift pumps last 100,000+ Miles.<br><br>On Customers trucks that don't refuel until below 1/2 or 1/4 tank the pumps average 30,000 or less.<br><br>When I installed the first few carters on the frame as pushers I would add a filter before the pump to help keep the Pump clean.... But even with regular filter changes the pumps were still failing at 30,000-80,000 miles. So I removed that very small suction restriction(My Pre Filter) and not ONE Pump has failed yet. <br><br>IN short these pumps are great as a pushers as most pumps are. Cummins merely mounted them on the engine because of concerns of the OEM using the CTDs not suppling a good Fuel feed. These 5.9CTD's are Designed and Advertised as a Complete and ready to run Power plant that a OEM can just drop in. Add a Fuel Line, Coolant Lines, 12Volt Battery source, simple Starter Key switch, adjust the OEM's requirement for HP,Torque and Rpm spec into the computer and Bingo they are ready to go. <br><br>(Except for dodge --- Who wanted their own Non adjustable computer, Cheaper exhaust manifold ETC!).<br><br>Kurt..... P.S. I have found the Carter HP pumps even cheaper!!
jrv15
21
May 28, 2010 11:05 PM
ryan10
Aug 6, 2007 03:29 PM
Jc9995
May 1, 2005 11:48 AM
deezulsmoke
26
Jan 28, 2005 11:13 PM
Big Rich
Feb 1, 2004 01:57 PM
