Help!!! Please!!!
Old Apr 25, 2007 | 08:03 AM
89ranger's Avatar
Yeah i have a scanner at my house here. I will check it in the next couple days
Old Apr 29, 2007 | 03:26 PM
89ranger's Avatar
I finally got around to scanning my codes on my truck but it came up empty. I have talked to a couple diesel shops and they say that my truck sounds normal and put a chip on it and it would change it alot. Does this sound right?
Old Apr 29, 2007 | 03:37 PM
P.J's Avatar
P.J
Not really, especially if they used the term "chip".
Old Apr 30, 2007 | 06:54 AM
Valv's Avatar
I am thinking that i have a bad injection pump and if that is true i am just going to sell the truck
How much ???
Old Apr 30, 2007 | 08:22 AM
89ranger's Avatar
Sorry, aftr looking at the prices of a different truck i am going to kep it for awhile. All the shops say my pump is in good working shape so i will keep it and find out.
Old Apr 30, 2007 | 11:47 AM
mo.redneck's Avatar
Buddy with all things considered you should go to advanced auto parts and get a boost gauge it will run you about 40$. thats pritty cheap. Just use the mounting bracket that comes with it and put it in the hole on the right side of the raido. save time and money. also look at diesel power they have a tech deal in Nov 06 issue about pyro and boost install.
Old Apr 30, 2007 | 12:54 PM
89ranger's Avatar
I got a free fuel pressure guage i just need to find a pod or universal mount for it but i am not going to plug my dash hole. I think i am just going to save up for a juice w/ attitude moniter and that has all the guages in it. plus i will have the chip so it would kill two birds with one stone. My next thought would be maybe a bad injector but not sure yet???
Old Apr 30, 2007 | 08:09 PM
Awall's Avatar
A guy i know has a 3500 and its a 6-speed and hes a diesel mechanic and his truck seemed to be haveing the same problems and it was determined that it was the throttle position sensor.. maybe that info will help some
Old Apr 30, 2007 | 10:11 PM
crobtex's Avatar
They are probably right. My '99 pulling a 7K# travel trailer was a real dog until I got to cruising speed, then it pulled fine. Mine is a 5 spd, not auto.
I added an Edge EZ and RV275 injectors and it really woke the truck up. Especially in 3rd, 4th and 5th. Not a race truck, but towing is now very acceptable.
Old Apr 30, 2007 | 11:56 PM
PaulDaisy's Avatar
Fuel pressure gauge: $7. Air pressure gauge: $7. nylon lines, tapped bolts: $20. Total: $35. No need to get the newest and coolest set just to get information.
And, Dmax with Allison is a good truck. Too bad it can have mechanical problems too.
Check out Surplus Center.
-P
Old May 1, 2007 | 12:14 AM
89ranger's Avatar
Thanks for the help guys. Does anyone have any articles on the Throttle Position Center?
Old May 1, 2007 | 05:34 AM
P.J's Avatar
P.J
Look in the "Tech Facts" section up top there, it's under APPS.
Old May 1, 2007 | 11:39 AM
REDNECK-WELDING's Avatar
will tha work for autos?? and if it is out would it throw a code or not? thanks
Old May 1, 2007 | 04:54 PM
crobtex's Avatar
They don't have to be throwing a code for the reset or recalibration to help.
jamesbfishin
Apr 16, 2016 11:32 AM
DHT
Apr 2, 2010 07:12 AM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
Lary Ellis (Top)
May 21, 2003 10:16 AM
