Help... Found this in my Trans Pan!
Old Aug 23, 2009 | 11:41 AM
North_of_55's Avatar
The other day I lost second gear for a few minutes... it's been working fine since.
I just dropped the pan to check things out and found this stuck to the magnet. It appears to have broken at one end... other end looks like factory shear. Can anyone identify this and suggest a likely source?
I changed the fluid and filter a few months ago. There is very little else on the magnet and no signs of any friction material in the pan.
Any help would be appreciated!
Attached Thumbnails Help...  Found this in my Trans Pan!-end-view-.jpg   Help...  Found this in my Trans Pan!-thickness.jpg   Help...  Found this in my Trans Pan!-side-view-.jpg
Old Aug 23, 2009 | 12:47 PM
J BODY's Avatar
That would be a broken snap ring. Tear it down before serious damage occurs.
Old Aug 23, 2009 | 01:44 PM
Clutch Pack Snap Ring?
After looking at the drawings (and holding the fragment flat against a straight edge) I'm pretty sure that it's a piece of one of the clutch pack snap rings.
I have never had a truck with so many problems in my life! Every time I get one problem fixed another comes up!
It's back together now... it's going to have to last until I can afford to fix it. If it goes it will hit the dumpster and hopefully get replaced with a 5-spd!
mar67655
Mar 14, 2009 07:22 PM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
