help on cooling service
Old Jun 7, 2004 | 02:26 PM
bws's Avatar
bws
help on cooling service-please
what p/n or thermostat temp do i need for my 01 24v ?? ive come up with no less than 6 p/n,s for thermostats??do i need a 180 or 190 for light/medium towing and any recs on antifreeze??thanks bws
Old Jun 7, 2004 | 03:37 PM
thumper 549's Avatar
please buy from cummins as there has been several updates......ask hoss
Old Jun 8, 2004 | 02:18 PM
bws's Avatar
bws
at 58k not sure if i should throw a t-stat in or not??am going to flush system tomorrow.
Old Jun 8, 2004 | 08:56 PM
Pa outlaw's Avatar
why are you changing it?if its running hot clean the radiator out,pull it out and preasure wash it it will probably solve a heat problem,my 01 was running hot,and if you replace your thermostat put a cummins one back in,go to a dealer and spend the money i tried others in mine and it ran hotter,good luck
Old Jun 9, 2004 | 06:01 PM
bws's Avatar
bws
should i use tap water or distilled water for mixing with the antifreeze??i hear diferent stories on this?? the stat p/n they gave me from cummins is 3946849 and is 56.00 and the seal is extra$$ ouch.does this seem like the right 190 degree stat??
Old Jun 9, 2004 | 10:37 PM
fschiola's Avatar
Here is some info you might find helpful.
http://dodgeram.org/tech/dsl/Facts/01ISBspecs.html
You might like to consider this coolant.
http://www.fleetguard.com/fleet/pdfs...es/LT32530.pdf
I have this in my 2000 and am going to put it in my 1997 as well.
I think the coolant manufacturers recomend using de-mineralized (soft) water.
steelblitzkrieg
Oct 14, 2011 09:19 PM
dieselbeef
Jun 12, 2006 08:12 AM
CattleKev
13
Jan 9, 2006 04:55 PM
mopar2ya
Apr 1, 2004 06:42 AM
