heat exchanger -- both sides
Old Nov 20, 2010 | 04:57 PM
dkenny's Avatar
Post heat exchanger -- both sides
I search and found lots about removing the transmission lines from the heat exchanger. Some confusion on sizes and which years have them..I don't the sizes on mine yet..but its a 99 auto ( rebuilt, from proformance powertrain). I'm not the first owner..no matter the exchanger itself is rusted away..so much that it leak transmission fluid..not fast..at least not yet..
I plan on couple the 2 transmission lines together..
what I'm wondering about..is if the heat exchanger is rusting bad enough will to also start to loose coolant? and the coolant side of the heat exchanger be bypassed.
I'd like to remove to completely..one more rusting part gone..
sometime I wish I had waited until a southern truck was at the right price...but I cannot complain..its not a 53 block... and might have a great tranny rebuild..
any thoughts??
-dkenny
Old Nov 22, 2010 | 04:26 PM
dkenny's Avatar
well I removed the tranny lines this past weekend..
I still hoping the coolant lines in the heat exchanger are good..
-dkenny
Old Nov 22, 2010 | 05:18 PM
rebal's Avatar
you can remove the whole thing but if you live in the north you might want to find a good used one to warm up the ATF in the winter and install some ball valves to shut the heat xfer off in the summer
Old Nov 23, 2010 | 06:29 AM
dkenny's Avatar
I don't live up north. I think bypass the coolant lines and leave it sitting there. one day I hear a big clunk as it falls off.
Thanks
-dkenny
jmccart
Nov 16, 2007 08:04 AM
BRUISER
Jun 5, 2007 03:04 PM
haloman
May 5, 2007 01:24 PM
gdh11
Apr 7, 2004 01:18 PM
