Hard Starting...could it be a fuel system problem?
Old Dec 13, 2006 | 02:06 PM
Rick_Orcutt's Avatar
O.K. I am starting to have problems occasionally when I try to start my pickup. I have noticed a small to medium sized spot in my driveway regularly and it appears to be diesel fuel. The location is right underneath the fuel filter (although I have checked to make sure it was tight and the valve was closed). Last night and a couple of times before, when I went to start it, it acted as if it had been run out of fuel (spitting, sputtering and dieing a couple of times before it starts up and keeps running). Could I have something going out, or is there something else I should check.
Thanks for any advice,
Rick
Old Dec 13, 2006 | 07:07 PM
01PPUMP's Avatar
I have seen some old lift pumps leak out the elec. plug and also where the tops and bottoms are put together. I Have even had new ones leak. Worth a
check.
Old Dec 13, 2006 | 07:27 PM
PChouinard's Avatar
Check the rubber plug around your fuel filter heater element. I sprung a leak there a while ago and I am having to clamp my fuel line below my vp after every shut down just so I can start it again. Bump the starter and let the lp run. Look all around tthe ff canister and all the fittings for the smallest and I mean the smallest of leaks. Agood idea is to clean the engine before hand.
Also, That quote in your sig. may have come from Gen. Patton. It sounds familiar
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
DNRCustoms
19
Feb 19, 2011 06:20 PM
big builder
37
Dec 12, 2007 07:07 PM
abc4yew
Mar 15, 2007 11:55 PM
