Hard Starting ~
Old Dec 6, 2006 | 05:16 PM
deuceandahalf's Avatar
Hard Starting ~
My '99 R3500 (160k) started to hard start awhile back; i.e., instead of it's usual turn the key and light, it would take progressively longer to start. Also, it seemed to me that the engine did not have as much oomph (technical term) as it usually has. I installed a GDP lift pump, no help. Plenty of fuel at the injection pump. Thought it might be the module on the VP44. Tried to remove it, but after removing the four obvious bolts, it wouldn't budge. The manual doesn't address this problem. Any thoughts? To put it another way - can the module on the IP be romoved, or is it part of the IP?
Old Dec 6, 2006 | 06:51 PM
Tate's Avatar
Are you on your original VP? Have you had your codes checked? Do you know what your fuel pressure is?
Old Dec 6, 2006 | 08:05 PM
high country's Avatar
could be a plugged filter, bum pump, small air leak in fuel ine. do you have a fp guage? it could amswer a lot of your questions. it would also pay to toss a scanner at it.
Old Dec 7, 2006 | 07:02 PM
bentwings's Avatar
I'm right inthe middle of replacing a failed vp-44 and this is exactly the way it started after I look back on it.
Early this summer it started taking a little longer to start. I wrote this off as the starter as I had put a new one on a couple months earlier. Then as fall came around the cold starts got longer and slower. Again I wrote this off to ULSD and winter fuel. I also noticed the few times I used full throttle it started out slow and built up to power at about 2000 then at 2700 it defuels. Below 2000 it seemed down on power but I really didn't think it was the IP. I also had a slight drop in gas mileage. I keep very close watch and it dropped about 1-2. I used to get 21-22 mpg then it went to 20 then it became very hard to get over 19.5. Now with winter it was down to 17 which is as low as it ever get int he worst weather.
Then out of the blue it just quit. After a lot of checking and test it is clearly the IP so I now have one on the way and have a large crater where my wallet was haha if it is funny.
I'll post the whole story later
Old Dec 8, 2006 | 02:35 AM
Thx Tate ~
Yes; No; & No.
Thanks - checking...
Old Dec 8, 2006 | 02:36 AM
Thx High Country - can you suggest a scanner?
Old Dec 8, 2006 | 02:43 AM
Thx bentwings ~
bentwings? Gotta know where that handle came from? "and the plane will fly?" Retired United pilot - just curious...
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
L. D. Bryant
Nov 17, 2002 12:18 PM
