Hard Shifting at a stop and squeaking?
Old Dec 27, 2008 | 06:46 PM
jethroish's Avatar
'02 2500 5speed, 137,000 miles
Things have been working fine. This morning when I left to go the donut shop before heading home from Christmas, it was quite hard to get the truck in gear while at a stop. Truck turned off, in and out of gears without problem; truck running, difficult to get into any gear, including reverse.
Once I got moving, she shifted just fine as normal.
Kicker is this, me, wife, and dad all heard, what sounded like the belt squealling slightly, but seemed to be coming from under the truck when attempting to put the truck in gear. Did not make the squeak when depressing the clutch, but rather when pulling the shifter gently back into 2nd. Something misaligned?
Now, fast forward 450 miles to home. Truck seems to be shifting normally again. Knock on wood.
Got me puzzled.
Clutch? syncro? slave cyl?
Old Dec 27, 2008 | 07:42 PM
badme's Avatar
pilot bushing is seizing up. That is your squeak and while it is doing this the input shaft is still turning. That is why it will not go into gear at a stop. When you are moving it is kinda like speed shifting.
Old Dec 27, 2008 | 08:10 PM
jethroish's Avatar
Not knowing a lot about trannies and do not want to attempt to fix one, will the pilot bushing require a complete rebuild/reman tranny? Is this common with my mileage?
Old Dec 27, 2008 | 08:39 PM
tonyd01's Avatar
no,all you have to do is pull the tranny out pull the fly wheel remove the pilot bering replace with new one assembel everithing and go on your way.
Old Dec 27, 2008 | 08:46 PM
jethroish's Avatar
Thanks for the replies. Now I have to find a good/reputable shop here in southern Indiana.
Old Dec 28, 2008 | 09:24 AM
badme's Avatar
If I was going to pull the tranny and take off the clutch to change the pilot bearing, I would put in a new clutch while I was there.
Hoss
0
Mar 25, 2013 09:10 PM
barttly
Jul 21, 2012 07:53 PM
Gbuilders
May 8, 2007 02:20 PM
royta
Nov 6, 2006 08:19 AM
big red psd cc
Jul 27, 2005 04:53 PM
