H.O. Engine ?
First year for the H.O. was 01 and here are the differences (from dodgeram.org):
"What's new in the ETH engine:
* Electronic Controls: New ECM calibration and fueling algorithms.
* Fuel Pump: Increased fuel flow in the Bosch VP44 injection pump.
* Injectors: Designed to provide increased fuel flow.
o Injector note posted to the TDRoundtable by tgbol:
+ ETH injectors (3946306) flow 600cc at 100bars for 30 seconds
+ ETC injectors (3944828) flow 640cc at the same test.
* Turbocharger: Revised wastegate setting for 26psi at the turbocharger outlet.
o Manifold boost specification is 43.5 inches Hg / 21 psi
* Head: Valve seat inserts for added durability.
* Pistons: New pistons with higher 17:1 compression ratio.
* Flywheel: New flywheel with 330 mm diameter clutch (vs. std. 310 mm).
* ISB Design Improvements and Features - from 1998 Mastertech
* FWIW: Reports from owners indicate that ETC engines are more responsive than ETH engines are to the major fueling boxes."
I dont know about that, I have a HO and my dad and grandpa both have the SO and mine seems to out pull thiers, with better mpg too. That might be because of the stick over the auto though.
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
