Guess What
Old Feb 18, 2008 | 10:23 PM
Vern Calhoun's Avatar
Guess What
Ok, so back in December I went home on leave (1300 miles) and while I was there the Holley decided to retire itself while I was driving and ended up having to drive the truck almost 1/4 mile with 1-2 pounds of fuel pressure. I pulled over when I could and replaced the Holley and its been fine ever since this week. So far 3 times in the last 2 days it has taken almost 2 seconds for the motor to fire and run. Could this be from an IP on it's way out? Mind you I have ran 2 stroke oil in the fuel for the last five months and I only need this thing to last another 3 and then it will be put in storage for 15 months. Any way to nurse this baby into storage?
Thanks, Vern
Old Feb 19, 2008 | 06:34 AM
xtoyz17's Avatar
Whats your fuel pressure? Filter clogging? Fuel leak? Error codes in computer? Check the usual stuff first.
Shawn
Old Feb 19, 2008 | 07:10 AM
Adam3291's Avatar
Maybe but I doubt it, the killer of the IP is LONG peroids of low fuel pressure. Check the fuel filter and change if needed.
Old Feb 19, 2008 | 10:00 AM
No codes or leaks. FP is 24ish idle 15 WOT. Changed the filter like 6k ago, think it's time to change again? What's yalls definition of a LONG time?
Vern
Old Feb 19, 2008 | 10:10 AM
fordkiller43's Avatar
Real long enough Vern.
Dojman
Apr 21, 2003 06:11 PM
cr1998
Nov 25, 2002 08:49 PM
dodgeram
Nov 16, 2002 11:32 PM
