grid heater relay
Old Dec 22, 2005 | 05:44 AM
deezel's Avatar
grid heater relay
truck acted like alternator cut out .voltage w/ engine running 11.8.overnight batterys dead and grid heater boot melted housing discolored.manual says both replaced as a unit.wonder if heater damged etc.anyone have a similar experience,and advice?
Old Dec 22, 2005 | 06:32 AM
Commatoze's Avatar
Sounds like the relay got stuck closed. the contacts might have gotten a little carbon on them and they eventually weld shut when all of the current has to go thru a reduced surface area. The grids pull a total current of 180 amps. That's a heckof a lot of current, so it doesn't take long before your batteries are fully discharged. So the relay is probably toast. I'm not sure what you mean by "grid heater boot". Do you mean the grid heater housing located under the intake horn? If so, I think mine is aluminum. Can you elaborate? In the meantime, if you pull the relay, you can continue to drive her until you get things fixed.
Old Dec 22, 2005 | 07:14 PM
deezel's Avatar
the boot over the electrical stud on the heater
Old Dec 23, 2005 | 04:55 PM
Commatoze's Avatar
OK. Then I think I'd just replace the relay. I was looking at the boot on the wire today, and unless there's bare wire showing, I'd just leave it undisturbed.
Old Dec 24, 2005 | 05:48 AM
deezel's Avatar
replaced relay today, $70.00 at dealer.also bought gaskets for heater assembly thinking maybe I should take a look at it.wondering how durable these elements are and if they could come apart and scatter through the engine.After knowing what I know now I probaly could have got out and smacked relay when volt meter woudn't come up.I put a test light in truck , probably wll never happen to me again but maybe will help someone else.Thanks for the reply.
Old Dec 24, 2005 | 07:59 AM
MnTom's Avatar
My understanding is that you could put a ford starter solenoid on for less money and they are built a little heavier.
Tom
Old Dec 24, 2005 | 05:42 PM
TORQUE's Avatar
Putting a ford part on a CUMMINS, how disgraceful.
1955raw
Feb 16, 2006 11:44 PM
rgadagno
Mar 11, 2005 09:53 AM
Geico266
Jan 8, 2005 06:39 PM
hobbyman
Feb 13, 2004 03:23 PM
midwestdually
Jan 19, 2004 11:25 AM
