Gradual Power Loss
Old Jun 29, 2007 | 06:25 AM
WildeKurt's Avatar
Gradual Power Loss
I have a 98 Ram 2500 5.9L 24V. Mechanically, the truck is in good shape (it looks like a Mad Max reject). After 100 miles of sustained high speed driveing, 70mph or so, it gradually looses power. If I leave the fuel cap off it much better. With fuel cap on I can hardly sustain 60mph eventually. Is there a vent somewhere that is blocked?
Kurt
Old Jun 29, 2007 | 06:53 AM
Tocapet's Avatar
Look on the top of your fuel tank. There should be 3 connections. Hoses run to 2 of them and the other one should be open. If it has a black or red cap on it, take it off. You can also see if it's blocked by cleaning around it, then connect a piece of hose to it. Take the fuel cap off and listen there while you blow into the hose. See if you can hear the air.
Old Jun 29, 2007 | 08:09 AM
nickg's Avatar
I believe as well there is a pressure & vacuum valve in the fuel cap as well(at least on a chev diesel there is. if its faulty it can/will callapse the fuel tank quite easy, (good thing the dodge has a plastic tank). FWIW, my vent on my tank(as described above) was plugged solid with dirt/mud, as the previous owner lived on dirt road
Old Jun 29, 2007 | 08:17 AM
johnh's Avatar
you would think a truck that old would not still have the cap?
Old Jun 30, 2007 | 01:10 PM
WildeKurt's Avatar
I can just see the top of the tank. It looks like there may be something on the third connection. Hard to tell for sure. It's a full tank so I can't drop it just yet. Thanks for the tips though.
Old Jun 30, 2007 | 01:46 PM
nickg's Avatar
You dont need to drop it, look in from the pass side
Old Jun 30, 2007 | 02:21 PM
tractorguyacb's Avatar
I had a Dodge in work do the same thing to me, i went to the local auto parts store and got a new fuel p because i could not suck through the old one. Good diagnosis and idea be that you took off the fuel cap to see if it got any better
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
justagoodolboy
Jan 10, 2008 08:33 AM
Ranger 2/75
Mar 16, 2006 05:07 PM
