Gears
You should find a factory sheet on the hood and it will tell you. If its gone then when you run 70 the rpm's should be around 2 if it has a 3:54's any higher rpm and it should be 4:10's
Originally Posted by Tayloe08
Does anyone know what gears would be in my truck? How does that relate to towing and MPG...good or bad?
Randy
P.S. Some upgrades to your tranmission will do a lot for your milage and pulling ability.
Those are 4.10's if you are revving that high at 70 mph with an auto..either way, your build sheet will tell you.......that should be on the under side of the hood near the latch and it will state the ratio.....I'm not certain, but I thought it was 00 and later that had the build sticker on the inside of the glove box door?
Just checked under hood and in glove box but no sticker! I know the truck has been repainted (at least the doors, fenders and hood) so that is probaly the reason for no stickers. I was thinking I would be able to use the VIN and the dealer. Would this work. Not an important factor right now I am just curious.
Yes, the last few numbers in the VIN are only any good to the dealer.....these are the #'s that contain the info that will allow them to reproduce the original build sheet.
BigJohnston
20
Jul 14, 2019 10:58 AM
