Gears
Old Sep 22, 2006 | 09:57 AM
PK's Avatar
PK
Gears
OK I feel dumb.
You guys are always talking about your gear ratios and I really don't know what I've got..... How can you find out?
Also, can anyone give me a crash course on what is better for what.?
Thanks
Old Sep 22, 2006 | 10:08 AM
jlipskoc's Avatar
94-02's have 3.54 or 4.10 gears.
On my 94 theres the factory build stick under the hood, its listed there.
Or you can check your rear diff, theres a metal tag strip on the right side thats its listed on there also.
RPM's are an easy way to find out, Manual 5sp, 2k rpm @70mph = 3.54 gears.
More info here: http://www.dodgeram.org/tech/specs/axle/rear_axle.html You have a Dana Axle, 70 or 80 depending on model and trans choice.
4.10's good for mountains, heavy towing, or use with an 47re auto.
3.54 good for mpg, better mileage, manual trans.
John
Old Sep 22, 2006 | 10:13 AM
jlipskoc's Avatar
Good Article for speed comparison:
http://www.dodgeram.org/tech/specs/axle/rpm_vs_mph.htm
Old Sep 22, 2006 | 10:16 AM
GSP's Avatar
GSP
On your 99, open your hood and look up. there is a sticker with the options and your gear ratio. Or crawl under there and look at the metal tag attached with your diff. cover bolts
Old Sep 23, 2006 | 11:09 AM
Mike Stowe's Avatar
Here is the tag under the hood.
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
