Gas Milage Change
Old Mar 17, 2010 | 03:50 PM
poogan's Avatar
Gas Milage Change
I Know my truck is a 1999 and has 196,000 miles but I've been getting 24/26 MPG for a long time but in the last couple of months its gone to 19/20 MPG and wanted to check on line before going to a dealer. Does anyone have an idea why the change in MPG??
Thanks
Old Mar 19, 2010 | 11:18 PM
bd02dad's Avatar
The dealer will tell you that as much as it's supost to get. But you might change your air and fuel filters. I've heard a weak IP can couse low MPG's also.
Old Mar 20, 2010 | 09:42 PM
cmmins's Avatar
I also heard winter fuel does not get as good MPG.
Old Mar 20, 2010 | 11:37 PM
bcbigfoot's Avatar
I'm new to the cummins 24v but I have seen some strange mpg numbers from the overhead display, the display mpg average is very accurate over a tankful of fuel, but I have noticed that the instant mpg numbers start at 12mpg (loaded truck) starting a highway trip then over 15 miles slowly increases to 15mpg, I don't know if its just my truck or what but there seems to be a change in performance and mpg as the temps increase. The only thing I can think of is the fuel timing advance changes with Intake air temp. and it takes way to long to get IAT's up especially running empty.
Old Mar 20, 2010 | 11:57 PM
trainermg's Avatar
Fuel
I would be woundering if the injecters are slobbering and not delivering the fuel to the cylinders in a fine mist like they should.Get some good injector cleaner put a bunch of it in your fuel an run a tank of it throu there.At kenworth a guy told me the unhook the fuel line and run straight cleaner in there to clean them.
Old Mar 21, 2010 | 01:35 AM
poogan's Avatar
Thanks for the replies, could be winter fuel and may be injectors, I'm heading out for a trip so before I see a dealer I'm going to check it out during the trip.
Dually Driver
13
Nov 13, 2007 09:10 PM
JKM
Oct 26, 2005 07:14 PM
dustbomb
Jul 19, 2005 09:29 PM
hipsi
Jun 1, 2005 03:50 PM
Jmac
Apr 14, 2004 04:28 PM
