Funny sounds under the hood
Old Aug 26, 2005 | 10:09 PM
wennis1's Avatar
I own a 1999 2500 Dodge 24V Turbo Cummins. Sometimes lately when I crank the motor a noise comes from the engine that sounds like a vaccum cleaner or something. When I try to shut her down..she makes a high pitch sound and doesn't shut down normally. I am a new member and could use any help with identifying this noise and how to prevent it from happening. There is 118,000 miles on my truck if that helps. Thank You.
Old Aug 26, 2005 | 10:13 PM
Marine's Avatar
Veteran: Marine Corp
It sounds to me like it is your fan when you start it, and the squeal is the serpentine belt. When your motor stops, your fan keeps spinning a bit. Hence the squeal.
Mike
Old Aug 27, 2005 | 06:29 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Might be a bad fan clutch.
Does the fan spin freely (with the engine off, of course) by hand when the engine is cold?
Old Aug 27, 2005 | 09:56 AM
darrenG's Avatar
hey, could be worse, sometimes after or when I turn my AC on I get a loud bang from somewhere in the engine compartment. Sounds like it's against the firewall or near passenger feet. oh well.
Old Aug 27, 2005 | 10:39 AM
wennis1's Avatar
Yes, I can spin the fan but not far. It stops after about 3 inches.
Old Aug 27, 2005 | 07:35 PM
dealerjim's Avatar
Mine does the same thing every now and then. It's almost sounds like someone smacks the compressor with a hammer. It usually does it the following morning after a long trip or towing.
TurboAZ
Oct 10, 2005 08:34 AM
bigair
Oct 26, 2004 04:36 PM
SuperDave4x4
Jun 30, 2004 11:56 PM
Dodgezilla
Feb 13, 2004 03:40 PM
TE-44
Nov 19, 2003 09:04 PM
