Fuel/starting problems.
Old May 9, 2010 | 08:21 PM
kpriester's Avatar
I just got a 98 Dodge 4x4 extended cab with 5.9 cummings if you park it facing downhill it starts and runs fine, if you shut it off on level ground for more than a few minutes it will not start. Lift pump changed and seems ok. Can't find any leaks and check valve holds. No problem with power while driving. My first diesel but it runs great other than the starting. Any suggestions?
Old May 9, 2010 | 08:36 PM
diggerfan99's Avatar
Have you checked fuel pressure out of the lift pump?
Old May 9, 2010 | 09:17 PM
Junk Man's Avatar
Mine was leaking at the T fitting where the over flow line meets at the back of the head on the drivers side. I don't know if the 98 has the same set up. I tried snugging up the fittings which works sometimes and ended up replacing the bushing. They are about $4 each. (edit: $8 each - 4 is too cheap. They are simply a short length of the proper size hose.) You need 3 of them but don't need the T itself. Cummins had a hard time finding them & had to go look at an engine. They are easy to get to with the stock lift pump moved out of the way.
Old May 10, 2010 | 11:15 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Rotten return fuel line, it is allowing air into the system. Check all your rubber hoses at BOTH ends and replace with quality diesel rated line only.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
