fuel pressure on start up 1999
Old Dec 1, 2008 | 04:02 PM
olddodgetrucks's Avatar
what should the gauge read before engine starts ,i have the f/p gauge on the filter housing
Old Dec 1, 2008 | 04:31 PM
RVTraveling's Avatar
Zero. On a stock setup the FP does not kick in until the starter hits.
Ken
Old Dec 1, 2008 | 05:11 PM
what is the reason it is wired that way,i would think fuel pressure when the key is turned to run would be better for the pump
Old Dec 1, 2008 | 06:09 PM
Barney's Avatar
There are two duty cycles for the stock lift pump. One is half-speed during cranking and the other is full speed during engine operation. You should see 4 to 7 psig during cranking and about 11-13 at idle. The engine usually starts quick enough that you have to be quick to notice the cranking pressure.
The VP-44 needs to be 'primed' to prevent damage during cranking. This is why they switched to the electric lift pump.
http://dodgeram.org/tech/dsl/mt_2_feb98/fuel_sys_2.htm
Controlled by the ECM, the transfer pump uses pulse width modulation to provide two duty cycles: full speed when the engine is running and half speed at crank to prevent overpressure that could keep the injection pump from operating.
Old Dec 1, 2008 | 06:40 PM
johnh's Avatar
the lp will run for 2 seconds after you turn the key on.....
Old Dec 2, 2008 | 12:28 PM
VADSLRAM's Avatar
Ken
As soon as I turn the key my LP cycles on. It did it with the stock pump and the FASS harness takes the relay power from the stock harness so it does it too.
I get about 14 psi on key. I usualy turn on the key, let the pump run a second then turn over the engine...don't know as how I need to but it's kind of a ritual now. Bat turbine to maximum and all.
Old Dec 2, 2008 | 12:47 PM
It may depend on how the truck is equiped. Mine is 24 valve, manual transmission, 2WD. When I change the fuel filter, I have to hit the starter, without starting the truck, to make the pump run and fill the filter.
YMMV
Ken
Old Dec 2, 2008 | 10:24 PM
johnh's Avatar
YMMV
Ken
johnh;2298927]the lp will run for 2 seconds after you turn the key on.....[/QUOTE]
Old Dec 2, 2008 | 11:51 PM
AggieJustin's Avatar
Actually, it depends on the programming in the ECM. The later ECM updates shortened this cycle to less than a second when going key on. My '01 used to run for a second or two when the key was turned on. After getting an ECM reflash and now with the Smarty, it just hits long enough to see some movement on my gauge.
I believe they shortened the run time when trying to work out some hard start issues. Now if you actually bump the starter without starting, you get ~45 seconds of run time for priming.
Old Dec 3, 2008 | 07:01 PM
what would happen if fuel pump was wired to run when key is turned to run,would make bleeding filter much easyer
Old Dec 3, 2008 | 08:06 PM
klx650a2's Avatar
The safest way to refill/bleed the system is to bump the starter. You do not want the pump to run full blast while the engine is cranking. vp44's are expensive.
jerry007
Aug 2, 2009 10:46 AM
cdj1942
Sep 4, 2008 11:07 AM
nelly
Apr 10, 2008 12:34 AM
robbob4
Oct 11, 2007 11:45 AM
JEric
Jul 24, 2005 10:18 PM
