1999 wont start
Old Apr 7, 2008 | 08:37 PM
nelly's Avatar
1999 wont start
I replaced the faulty lift pump & it started right up, I let it warm up & shut it down. Now It wont start. It seems Ive got descent fuel pressure, i hooked up a pressure gauge & it reads about 8psi on the outlet side of filter(thats when I hear the fuel pump noise). Is there any sensors etc. that I should be checking? Should I get a scanner on it? When it starts the check engine light stays on. Another thing, when I bought the truck, there was a brand new oil pressure sending unit(sensor)in the glove box, could this be why it isnt starting?
thanks
Doug
Old Apr 8, 2008 | 07:37 PM
PChouinard's Avatar
Could have a slug of air in the IP. Bleed the fuel system from the filter to the injectors and get it running again. Then pull codes to see why the CEL is on.
Old Apr 9, 2008 | 07:04 AM
nelly's Avatar
You were right, I bled all the air out & away she went! Now I need a code reader to see why the cel light is on. I read somewhere you can buy one at Wal-mart?
thanks again
Doug
Old Apr 9, 2008 | 08:48 PM
dspencer's Avatar
You can have codes read and cleared from some of the auto parts stores.
Some of your lights will go off by themselves after you have started the truck X number of times.
Old Apr 9, 2008 | 10:54 PM
Clunk's Avatar
Turn your keyswitch On-Off-On-Off-On then look at your odometer for trouble codes.
Did you put the sealing washers back on like they came off...one on each side of each fitting?
You can get a Free 25 Second Lift Pump Run by turning the keyswitch just enough to "bump" the starter then quickly release the key.
Old Apr 10, 2008 | 12:17 AM
PChouinard's Avatar
No key trick with the 99's. Thanx Dodge!
OBDII code readers are cheap and worth the money..
Old Apr 10, 2008 | 12:25 AM
Clunk's Avatar
"Ohh, it's the '99".....as the Clunk stumbles off mumbling to himself.
Old Apr 10, 2008 | 12:34 AM
Clunk's Avatar
You might check the fuel filter housing to be sure it's full of fuel then loosen the 19mm injector line fittings a coupla turns on #1, #3, #4 & #5 injectors and with the throttle floored, crank the engine over for 10 seconds to try to bleed off air in the system.
If the motor tries to start, turn the keyswitch off, tighten the injector fittings then restart the engine.
Check the loose fittings and tighten the wet ones then do another 10 second crank and check the remaining fittings.
Continue until all the fittings are wet & tightened down.
Retry the 10 second cranks, let the starter rest for a coupla minutes then retry.
leeboy
20
Jan 25, 2013 09:29 AM
chuckybones
Sep 17, 2011 11:24 AM
cdj1942
Sep 4, 2008 11:07 AM
robbob4
Oct 11, 2007 11:45 AM
qcstunter
Jan 9, 2007 04:10 PM
