fuel pressure gauge 101
Old Nov 4, 2008 | 09:32 PM
electromanj's Avatar
Hello, I have a new addition to the family! A 1999 dodge ram 2500 diesel. I already have a 1500 318. This is my first diesel. I have heard alot about lift pump problems, and that it's hard to notice until the pressure pump goes bad unless you can monitor the fuel pressure. Does anyone have any advice on what kind of gauge to use and how to go about installing it? I am wanting to get a code reader also and some of the ones I've seen display fuel pressure. Is that a better way to go? Thanks!
Old Nov 5, 2008 | 05:25 AM
stevewes2004's Avatar
get a mechanical gauge. i bought one from isspro and love it. it comes with an isolator but whether you want to use it is up to you. i didnt. good plumbing will assure you dont have leaks. i havent had personal experience with electrical gauges but ive heard they're not as reliable. either way, any VP truck needs one. installation wise the mech. guages are somewhat a pain. the only bad part is sealing the compression fittings. get them finger tight, then give it an extra 1/4-1/2 turn. the kit will come with a tapped banjo bolt that goes into your VP.
Old Nov 5, 2008 | 07:34 AM
Thanks, I looked on isspro for the kit and only saw the gauge by itself. Do you know the part number of the kit?
Old Nov 5, 2008 | 07:48 AM
mslashbar's Avatar
Check out www.vulcanperformance.com Eric will help you out with whatever you need.
Old Nov 5, 2008 | 09:58 AM
yeah vulcan is where i bought mine. i didnt buy the individual gauge though. i bought the 3 pillar gauge kit. you should be able to search within the vulcan website.
Old Nov 5, 2008 | 11:36 AM
Grider Pirate's Avatar
Warning on the cheap
If you just want a warning when the lift pump quits:
https://www.dieseltruckresource.com/...Cheap+DIY+fuel
Old Nov 5, 2008 | 05:36 PM
Nice project!
Another question. What pressures am I looking for? I have seen gauges 0-15 and 0-100 psi.
Old Nov 5, 2008 | 07:33 PM
klx650a2's Avatar
If I were you, I'd get the 0-30 psi FP gauge. From what I've gathered, you do not want fuel pressure over 20 or so psi as you'll damage the injection pump ($1500.00 just for the pump) and NOTHING under 5. Mine sits at 15.5 at idle and 12 at WOT. That is without the big line kit. Maybe I'll do it this winter when its -40...
Old Nov 5, 2008 | 10:20 PM
Tate's Avatar
Get a 0-30 psi gauge unless you plan on doing something more unconventional later (p-pump). I run electrics in both trucks, both run 40+ psi pressure, and no issues. Since you have a 99, your fuel filter canister will have two NPT plugs in the top, that you can put your fuel line or sensor right into as long as its 1/8" NPT. Saves money on tapped banjos, and time waiting for them to show up.
Old Nov 6, 2008 | 05:46 PM
Thanks, good advice. If you go mechanical do you have to prime to line going to the gauge to get all the air out? Or is air even a problem?
Old Nov 7, 2008 | 11:36 AM
nkennedy's Avatar
I didn't prime mine, and it wasn't a problem.
Old Nov 7, 2008 | 12:02 PM
klx650a2's Avatar
I primed mine as I'm kinda **** about stuff like that. I was concerned that air compresses different than diesel. Probably overkill, but...
Old Nov 7, 2008 | 03:22 PM
olddodgetrucks's Avatar
prime is not needed,it takes a few seconds to compress the air in the line,15lbs is 15lbs if it is diesel,air,anti freeze ect,
dodgeguy71
17
Jan 19, 2012 12:52 AM
stock600
23
Feb 8, 2008 01:46 PM
dodgethis91cmns
Jul 17, 2007 09:41 PM
PROSOUTH
27
Jan 27, 2004 12:56 PM
Racer57
14
Jun 26, 2003 06:57 PM
