Fuel Pressure Drops
Old Feb 17, 2005 | 05:09 PM
Big Smoky's Avatar
Fuel Pressure Drops
Right now at idle with the pusher pump I have about 24 psi at idle whitch is really good. But with the injectors, and the box set on 5x5 or even 3x5 the fuel pressure drops down to about 10 psi. Does anyone know why it would loose this much pressure? Thanks
Eric
Old Feb 17, 2005 | 05:15 PM
Tazman's Avatar
Are you sure your pressure gauge is good.
I'm thinkin that 's a bit high @ idle for the VP. Also assuming the LP is still there.
Old Feb 17, 2005 | 07:31 PM
gandrews's Avatar
From what I have read 24 psi at idle is on the high side.
A drop of 14psi is significant.
Double check the gauge.
Cause of the drop could be:
dirty fuel filter
restrictions in the fuel lines - do you have high flow banjos or a high flow fuel line kit?
restriction in the pickup tube in the tank.
Good luck,
George
ollie32
13
Mar 9, 2007 09:01 PM
javamann
Aug 14, 2006 08:54 AM
rbox
17
May 29, 2005 10:35 PM
Buckshotmckee
15
Apr 28, 2005 09:11 AM
dodgediesel4x4
Dec 3, 2004 03:57 PM
