fuel pressure
Old Oct 7, 2012 | 03:36 PM
ollieman's Avatar
fuel pressure
what should the pressure be on a 98.5 when at idle and then under power? can you check the higher pressure by just reving engine or do you have to drive?
Old Oct 7, 2012 | 03:40 PM
Shovelhead's Avatar
Administrator / Scooter Bum
"Normal" idle (stock pump) should be around 15-18 psi.
"Normal" Wide Open Throttle WOT under load (stock pump) should be greater than 8 psi.
Aftermarket Lift Pumps will change these readings depending on whose setup you've installed.
Old Oct 7, 2012 | 05:17 PM
ollieman's Avatar
why is the idle psi greater than under load?
Old Oct 7, 2012 | 06:18 PM
SIXSLUG's Avatar
Because the injectors are draining away fuel faster than it gets replaced by the pump.
Old Oct 7, 2012 | 06:24 PM
Shovelhead's Avatar
The Lift Pump is electric, not driven by the engine.
Increased RPM does not equal increased pressure/flow.
Old Oct 10, 2012 | 02:24 AM
peter50's Avatar
I am not quite sure but this problem could also be occur due to the radiator fault. if there is a bit leakage in radiator or it gonna empty then the fuel pressure will diffidently got up.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
