Fuel pressure
I've got 10 lbs of fuel pressure at idle at the vp44 and about 11-12# pre filter. This has dropped a little since I last checked it. After a new fuel filter it remains the same. I have an extended factory warranty but don't want the dealer to put the lift pump in the tank if its going bad. Should I just replace the campaign pump myself or wait for the VP44 to go? Also, will a fass or vulcan affect my warranty? Anyone? Thanks, Kurt
My personal opinion, if you have 10 psi and it doesn't dip too much under load then you are probably ok.
I think it's safe to assume that any modifications to the fuel system will decrease your chances of having warranty engine work done, especially a VP replacement, and especially a complete fuel system replacement like the FASS.
My VP is going (regularly throws codes) and the local dealer said no to a warranty replacement of mine based on the fuel system mods.
Thanks for your reply cditrani. When I got the truck in April it had 11-12# at idle and about 9-11# at wot. This drop seemed strange and has occured since the new ulsd fuel has been available. I don't know if that would affect it or not.
No codes before the FASS, but I don't attribute the VP failing to the FASS. My fuel pressure has been rock-steady since the FASS.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
