fuel milage!
Old Jan 30, 2003 | 04:06 PM
powerwagon440's Avatar
fuel milage!
what is everyone running on fuel milage on there 24 valves? i know alot of u are running high performacne stuff and towing. And from what i hear from alot of people there getting anywhere from 15 to 22 miles. i bought my truck in august and i just drive it on the weekends when i do drive it its all highway miles but i do like to race from light to light if theres another furd or cheby so i know my fuel mileage would be bad but the last 2 weeks i have driven it every day 50 miles a day. and i have not been mashin the pedal at all and my fuel light is on and i only have 350 miles on the tank of fuel. so that is like 10 miles a gallon! whats going on? i put a new iat sensor in cause i heard that it might help on the fuel milage abit. and all i have done was put the 275 injectors in and i thought they were supposed to make it better which it has alot but not on fuel milage. does anyone have any input on this?
Old Jan 30, 2003 | 07:06 PM
drecu's Avatar
Re:fuel milage!
What size Tires do you have? your lift pump may be dead this will also make you have bad fuel milage, also clean the MAP sensor!<br><br>DRecu!
Old Jan 30, 2003 | 07:43 PM
Davidp's Avatar
Re:fuel milage!
I'm stock on a 2001.5, 5 speed, and at 55 MPH I get 19 to 20 with a high of 22. At 70 to 75MPH I drop to around 16.5. I have 315-75-16s on the truck. I drive 42 miles each way over mountains to get to work. I usually get 99 MPG on the way down. ;D ;D
Old Jan 30, 2003 | 07:56 PM
Re:fuel milage!
i have 285-75-16 bf goodwrench tires. ill have to check out that lift pump then! have to dig threw all the post to find it cause somebody last week had a ? on it.
Old Jan 30, 2003 | 09:34 PM
whiteknight's Avatar
Re:fuel milage!
just did a test on ram at 65mph (no more than that) empty, got 21.58 ;D put little 8' camper (lowered and 40 degee front slope on camper 65 mph again got 17.001 keep tack below 2k and you should get good mpg ;D
Old Jan 31, 2003 | 06:04 AM
Copenhagenjunkie's Avatar
Re:fuel milage!
[quote author=whiteknight link=board=4;threadid=10291;start=0#98603 date=1043984069]<br>keep tack below 2k and you should get good mpg ;D<br>[/quote]<br><br>That is what I was thinking
Old Jan 31, 2003 | 07:20 AM
wheezer's Avatar
Re:fuel milage!
If your fuel light is like everyone else's you aren't going to get even close to 35 gallons in your tank.
Old Jan 31, 2003 | 07:37 AM
hellotbone's Avatar
Re:fuel milage!
No I get about 28 MPG
Old Jan 31, 2003 | 09:19 AM
KC's Avatar
KC
Re:fuel milage!
Right now I get around 18, I have gotten as high as 23!<br><br>KC
Old Jan 31, 2003 | 09:38 AM
Re:fuel milage!
jamie what is your secret for 28mpg. lowered, 2x,air wings ect or what?
Old Jan 31, 2003 | 02:36 PM
dodgeram's Avatar
Re:fuel milage!
well I was getting 21 mpg this summer, droped back to 17 mpg when winter hit(115km/hr cruise) ......<br><br>but I just got a set of rv275's and a comp put in, the old injectors were pretty carboned up .......<br><br>mileage jumped up to 22mpg, so I expect 25mpg this summer and don't see why 28 wouldn't be possible if I stayed at 100km/hr)<br><br>remember the canadian gallon is larger than an american gallon so 28mpg cad = about 24mpg american <br><br>
Old Jan 31, 2003 | 03:30 PM
Re:fuel milage!
at 60mph my truck runs at 2k! what am i supposed to do putt around like grandma? it just seems the more i drive it the worst the fuel mileage gets. my first tank i got 500 miles i was happy with that not happy with 350 miles. i just put 29 gallons in it today.
Old Jan 31, 2003 | 06:05 PM
WVPANHANDLER's Avatar
Re:fuel milage!
16 mpg running empty, 10-11 pulling 12,000 5th wheel<br>and 13 average around town emtpy. 1999 4 x 4 automatic<br>3500 215-85-16 tires. The best was about 17 mpg freeway<br>full trips. You surely don't believe the overhead readings.<br>My bell go off for fuel about 28 gallons. Have run the <br>reading overhead to 0 miles to go. About 31 to refill.<br>Hope this helps. I'm right at 99,500 miles. <br>Fully stock.
Old Jan 31, 2003 | 06:11 PM
Re:fuel milage!
heck no come on 28 miles a gallon? my dads 98 12 valve gets 15 to 18 and he drives it 5 miles to work 5 miles back thats it! i was just hoping for the same. lol i get better gas mileage with my 83 1/2 ton 4x4 318 4spd 600 holley 8inch suspion lift 3 inch body lift and 39.5 mickey tompson tires 4:56 posi rear! i can amagine if i had all kinds of hp stuff on it but i dont thats y i was asking if i had a problem like the lift pump or something like that.
