Fuel leak behind vp44
Old Mar 18, 2007 | 01:01 PM
Juniorphil's Avatar
i seem to have discovered a fule leak behind the vp44. Fuel is dripping down the block, any suggestions. Could be coming off the vp44 but think io saw couple drips going down the block behind it
Old Mar 18, 2007 | 01:57 PM
lovinCTD59's Avatar
I thought I too had a leak behind the VP, turned out it was the fuel line from the VP to hole #3. That fitting was loose. Never could really find it until it was so bad every time the pump would push fuel into that line it would shoot it onto the firewall Check all of the fuel lines, and let us know...
Old Mar 18, 2007 | 05:55 PM
Juniorphil's Avatar
alright i looked into it a little more cleaned up the area and started the truck. Above the High pressure lines off the pump is were th drip is coming from, can't see exactly were to much crap in the way.
Is there anything above the HP line outputs that could be causing it
i checked the fuel lines but could not get back to one of them,the other lines get in the way. It may be sqirting sidways on the block but it seemed to be dripping from above
robby t
Dec 16, 2013 09:22 PM
dieselfuelonly
Jan 24, 2012 10:16 AM
seahawkdodge
Sep 18, 2011 11:14 PM
leper
Feb 6, 2008 05:18 PM
bigbaddiesel
Mar 6, 2003 01:26 PM
