07 5.9 fuel leak from quick connect behind fuel filter
Old Dec 13, 2013 | 11:54 PM
robby t's Avatar
I have noticed a small fuel leak behind the filter, looks like the quick connect fuel line.... I need to resolve this problem any help would be appreciated....what parts how to disconnect etc.??
Old Dec 15, 2013 | 10:29 AM
vangasman's Avatar
Don't know what you have, they made two kinds. The ones with the blue plastic clip you just squeeze the clip together, if it's metal you need the removal tool that slides up the line to disconnect. Could also be one of the washers on the banjo fitting.
Old Dec 15, 2013 | 12:14 PM
robby t's Avatar
hey..thanks for the reply...well I tightened up the banjo fittings changed the filter & o ring checked the quick connects all looks good.....are there rubber o rings in the quick connects?
Old Dec 16, 2013 | 09:22 PM
vangasman's Avatar
They have a o ring in them although I haven't had to change one. I would assume that you can if need be.
dieselfan
13
Mar 20, 2018 08:58 PM
dieselfuelonly
Jan 24, 2012 10:16 AM
ripping r
Jan 5, 2010 06:58 PM
RHC
Oct 26, 2009 11:17 AM
chucktownsend5
Apr 3, 2005 07:53 AM
