Fuel Gauge Failure
Old Mar 12, 2008 | 07:10 PM
Twogun's Avatar
Fuel Gauge Failure
Fuel gauge is not reading correct amount, is there a sending unit in the tank that can go bad and what would you look under to find the part #? Twogun
Old Mar 13, 2008 | 09:10 PM
mini14's Avatar
to the instrument cluster check first c if that clears things up...it did for me....hold in the trip odo button turn key to run but do not start hold it there until all the gauges go haywire....its a diagnostic self check..
Old Mar 14, 2008 | 01:33 AM
Fishin2Deep4U's Avatar
Do you have a draw tube in the tank? It is possible that it is interfering.
Also, floats have been known to come off or get saturated.
Dave
Old Mar 14, 2008 | 09:45 AM
JARHEAD's Avatar
From my past experiences, it is the float level sensor in the tank. I have had three go bad. It costs around $65.00 from the dealer. Either drop tank or lift the bed. Will be a good time to install a draw straw at the same time!!!! I actually have mine dropped right now. part will be here today. By the way, when taking the wires out of the connector (for the sensor), DO NOT PULL THEM OUT!!!! use the tool or whaterver it is to take them out correctly or you will be buying a whole new fuel tank module $400.00. Can't buy the little electrical connector by itself.
Kip
IPDiesel
Jul 29, 2015 09:57 PM
Lightman
17
Jul 9, 2013 02:10 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
hawaiianbro
Feb 10, 2011 07:52 PM
torquedcummins
Jan 6, 2005 07:11 PM
