Fuel Filter Change
Old Jun 20, 2003 | 08:13 PM
phox_mulder's Avatar
Re:Fuel Filter Change
Big<br>Honkin'<br>Air<br>Filter<br><br>BHAF. ;D<br><br><br>phox<br><br><br>(kudos to DPG for borrowing his pic ;D )
Old Jun 21, 2003 | 07:15 PM
Cumminsdude's Avatar
HOLY CRAP. Where can I get my BHAF? I just got some graduation money and I got a free ride to college so hear comes my chip and BHAF as soon as I figure where to get them and what the best is.
Old Jun 21, 2003 | 09:45 PM
DPG's Avatar
DPG
NAPA part #2790. Cost around $50.00 here in N. Michigan.
Old Jun 22, 2003 | 10:40 AM
what about a heat shield? And does it look like that one in the pic?
Old Jun 22, 2003 | 10:27 PM
The heat shield you'll have to fab up yourself, or find someone handy with sheet metal to make you one.<br><br>The template can be found in the Tech Facts (line above in the main page graphic) , or from this link.<br><br>https://www.dieseltruckresource.com/...p;onlynewfaq=1<br><br>You can also get the BHAF from Cummins of Fleetguard, part numbers earlier in post as well, or from any major truck shop.<br><br><br><br>phox
Old Jun 22, 2003 | 10:48 PM
Thanks for the info. Anyone on this forum willing to make me a heat shield for a little bit of cash?
Old Jun 23, 2003 | 06:11 AM
Shovelhead's Avatar
Administrator / Scooter Bum
From the Tech Facts section at the top of the page:
Definition of Terms
BHAF= Big Honkin' Air Filter.
A much large filter, usually installed on larger commercial diesel engines that attatches directly to the turbo intake hose.
It allow more air, but can get wet, and pulls heated air from under the hood.
Old Jun 23, 2003 | 10:29 AM
WOW, thanks I didnt even know that definition page existed. Thanks. Oh yeah I had another question! When you say &quot;bump&quot; the starter to prime the fuel do u mean actually make the truck roll over for a short short second so it doesnt start or just turn the key to the on position? Because when I turn the key to the on position I can hear something like turn on and it sounds like a fuel pump so is it still necesarry to roll the truck over? Thanks again.
Old Jun 23, 2003 | 10:57 AM
Shovelhead's Avatar
Bump is engaging the starter for just a split second, to fool the lift pump into running for it's 30 sec start cycle.
Old Jun 23, 2003 | 03:24 PM
[quote author=Shovelhead link=board=4;threadid=16055;start=15#152416 date=1056383822]
[/quote]
Does this mean u are going to roll the truck over? I dont mean roll it over but bump it so it starts to roll and then stop instantly? Or just turn the key on?
I hate to sound like an idiot but I am just not sure on this!!
Old Jun 24, 2003 | 09:48 AM
Bearfoot2's Avatar
Bump means just very quickly touch the starter and let off. Don't try turning it over. When you turn the key on the pump cyles. When it quits bump the starter and it will cycle again. Each time it quits cycling bump the starter again. Do this 3 or 4 times, then turn it over to start.<br><br>Stan
Old Jun 25, 2003 | 04:13 PM
roadrat's Avatar
A method i use to bleed the air out of the system after a filter change is to remove the schraeder valve from the banjo fitting at the injection pump, put a snug fitting piece of hose over the threaded part and direct the other end down into a container under the truck on the ground, bump the starter once, at the end of the lift pump cycle a full stream of fuel should start to flow, remove the hose , replace the valve, and fire her up. Truck starts perfectly, no burps, farts, or stalling and a lot easier on the starter. ;D I picked this little trick up from a post on this site so thanks to whoever posted it origionally it really works.<br><br> rob<br><br>
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
