Fuel Filter Change?
Old May 22, 2007 | 06:47 PM
Don Baggett's Avatar
Fuel Filter Change?
This 98.5 is more complicated looking than the 01 I used to have. Can anybody tell me how I go about opening the thing up?
Old May 22, 2007 | 08:14 PM
Dinner's Avatar
Unplug the necessary connections, I think there is only one that I can think of(the water/fuel sensor). Drain a little bit of fuel of of the canister so you don't spill any when you take it off. Then begin to loosen the nut in the middle of the canister. This will stay on top of the lid, but allow the canister to drop down. Once fully loosened, then you just bring it out and change the filter.
Once you have the new filter in(should still be diesel in there, if not, put some in) and rub a bit of diesel fuel around the o-ring. Then put it all back together, making sure that the old o-ring came off with it when removing, and that everything is tight and sealed when all put back together. Hope this helps
Old May 22, 2007 | 10:07 PM
Thank you for the reply. I can do that, no problem. Thanks again.
Old May 22, 2007 | 10:29 PM
J Lent's Avatar
Yep...very easy to change....one bolt & one plug. After the filter is installed just get in the truck & bump the starter. You will hear the fuel pump run....when it stops running bump it again. You will have no problems with airlock using this procedure.
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
