FUEL FILTER
FUEL FILTER
I HAVE DONE IT ONCE......I WROTE IT DOWN......BUT IT'S MISPLACED SOMEWHERE....SOME ONE RUN THRU IT AGAIN PLEASE........OR JUST GIVE ME THE SITE THAT HAS IT ON THERE.......THANKS STROKE ON
Guest
Posts: n/a
Re:FUEL FILTER
I got a 99 and I belive mine is different then your. I loosen the nut on top and let the cansiter drop, pull the filter out and dump the fuel and wipe the cansiter out. Then fill the cansiter about 60% full with clean fresh diesel fuel, stick the new filter in and install the caniter back on. Truck fires right up.
Re:FUEL FILTER
Real easy get a 1 1/4 socket screw the cap off, take filter off and put new one on. Check O-ring on cap put new one on if needed re-install new filter and tighten it up. Start truck
Guest
Posts: n/a
Re:FUEL FILTER
I had to pop the cover off of my filter while it was still in the cannister. Couldn't get it out because of the suction with the fuel, didn't want to drain the fuel and lose prime. OK to do that, it worked. Top popped off with small screwdriver on tabs, and then filter came out with a sucking sound. (I have an '02.)<br><br>Ascraeus
Re:FUEL FILTER
http://www.dodgeram.org/tech/dsl/maint/3rd_Gen-24v.htm<br>I used these instructions and they worked well. Did mine last night.<br><br>Ron
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
Thanks for the info Shovelhead.
