fuel boss, school us
fuel boss.....any reason not to run it? i think this is the pump for me, could go ddrp but this will plumb right into my current set up with 2 filters etc... and be bomber no matter if either system blows out, what you think?
I have had mine for a while now. I LOVE it. If the engine is running I have fuel. Pressure remains constant NO MATTER WHAT. I did not use the electric lift pump, I just installed at as a stand alone pump.
i have a call into them, i guess DTT has something thats about to hit that has a filter on it too, might go that route depending on price etc...
are u just running a stock filter assembly?
i have a stanadyne lp on the frame that has a 30 micron filter into the stock filter set up, i think keeping that will be a good idea
yes stock filter setup. I have a pre filter that I bought to put on, but when I installed my pump I was in a time crunch, so the pre is still in the box yet. I got mine from our very own DTR store. Saved a bunch over the Glacier site, and still was dropped shipped directly from Glacier. Try the home boys first.
yep, looks like dtr has it cheapest, now should i do this or just plumb a raptor into the standyne spot and be done...? cant make up my mind, well i have , just dont want to spend more $, i think for $140 more than the raptor the only choice is the mechanical, talked to rich today and i have to check a few things before i know what i need to hook into my already modified system, but i think it should work fine, i just hope i dont have to drop the tank for any reason, now where did my sugar momma go to pay for this, hehehehehe
any reason to have more than the stock filter really?
I went through a couple electric lift pumps in the past 4 years. I am sick of the fail rate of the electric crap. My fuel pressure stays constant between 12-15 PSI at ALL times. I was gonna do the pre filter just to eliminate the possibility of lodging anything in the mechanical pump. The pump is aeasy to mount and offers great peace of mind.
Big thumbs up on the fuel boss. Like already mentioned, the engine needs fuel to run...if the engine is running, it supplies fuel... they go hand in hand. I've never seen less than 14 psi, and never more than 20. Plus, its uprgadeable. If you start making too much HP for it to keep up, you can get a smaller pulley to spin the pump faster, which supplies more fuel.
Wurkenman, I would like to see a pic of you prefilter setup if ya get around to installing it. Been wanting to add one to my truck eventually as well
dang it, i want the fuel boss, but i can get away with the raptor for a couple hundred less, Rich even agrees that it will be fine, and the raptor has a lifetime warranty now too, guess i'm gonna stick with the electric for now, should be more than enough psi for my set up and i can just plumb it right into where my stanadyne is nowand hook up the electrics and i'm done, probably take an hour to do it
The lifetime warranty is OK, but when it fails or gives you trouble, and it will eventually, you will be without a truck until the problem is resolved. That is why I went with the Fuel Boss. I do not want to have two fuel pumps on hand at all times, just in case one goes. I'm sure the Raptor is good pump. but I personally have had it with having to depend on the electric pumps. Keep us posted on the progress.
just gonna do the raptor and keep my current set up as a back up, i can guarantee i will regret this later and end up with a fuel boss, just need to blow more money first
, hehehe, but really i think i will be fine for quite awhile, rich said these pumps have been really reliable and he has only seen a couple of failures in about 7-8 years now, at least i will have a back up if i am out in the boonies
HarleyHauler
May 12, 2009 08:37 PM
03qclb5spd
Jul 11, 2007 04:51 PM
Ph4tty
May 8, 2007 08:38 PM
03qclb5spd
29
Apr 24, 2007 10:12 PM
