Front oil seal dilema
Old Apr 18, 2017 | 08:22 AM
k-oss's Avatar
Attempting to replace the front crank seal on my 2002. Seemed like a straight forward repair. There are some excellent Youtube videos available that don't address my particular problem however.
I put a wear sleeve on the crank seal area and now the plastic guide/seal lip protector supplied with the seal will not slip over the end of the crank.
I forced the issue and now I'm buying another seal as a result.
Hoping some of you Cummins expert have encountered this and can offer up a solution.
Thanks in advance!
Old Apr 18, 2017 | 05:21 PM
AlpineRAM's Avatar
Since the wear sleeve makes the crank snout bigger you will need the correct seal for the application with the wear sleeve.
(I hope you used the Cummins part for the wear sleeve, then you can get the oil seal through Cummins)
Should be part # 3802820
Old Apr 18, 2017 | 07:13 PM
k-oss's Avatar
That makes perfect sense but sadly that didn't occur to me. The youtube videos didn't mention it either. The seal and sleeve I bought are SKF. I wonder if there is a way to remove the sleeve and start over.
Thanks for the feedback.
Old Apr 19, 2017 | 02:55 AM
AlpineRAM's Avatar
Did they come as a set?
Maybe it was just mismatched...
Old Apr 19, 2017 | 08:27 AM
k-oss's Avatar
Did not come as a set. Heading to NAPA to try and get things straightened out.
Thanks
Old Apr 19, 2017 | 01:08 PM
AlpineRAM's Avatar
Good Luck!
Hope you get the correct seal for the sleeve and then you're golden.
PS- I usually don't need a sleeve, I measure the install depth of the seal before removal and install the new seal to a different depth so that it does not ride in the groove the old seal created.
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Jan 4, 2011 12:43 AM
RTillery
Feb 7, 2009 08:46 AM
dieseljerk
Jul 8, 2004 07:23 AM
owtlaw
Jul 2, 2003 05:27 PM
