front end pull, suggestion
Old Aug 16, 2004 | 01:21 AM
Haulin_in_Dixie's Avatar
I have recently noticed that the pulling of the front end is or can be controlled to some degree by the rear tires. Look at it this way, if you have a posi rear, it takes some pressure to make the clutches slip. Tires a little mis sized or different pressure will cause a pull. You might try a little higher pressure on one side to offset a pull condition. It makes a difference on mine. This would only apply to a posi rear.
mikeg135
Jul 18, 2007 09:19 AM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
Gunship Guy
Oct 24, 2003 09:23 AM
agcntry
Nov 13, 2002 10:21 PM
