Front Drive Shaft U-Joints
Old Mar 1, 2008 | 01:07 PM
Captum's Avatar
I am contemplating on replacing the three u-joints on the front drive shaft.
Besides the problems in getting the old ones out, is there anything that I should be aware of?
Old Mar 1, 2008 | 05:52 PM
jaredctd's Avatar
big hammer and heat
Old Mar 1, 2008 | 05:53 PM
jaredctd's Avatar
clean the holes really good before putting the new ones in, this will save a lot of headache too.
Old Mar 1, 2008 | 07:49 PM
mini14's Avatar
they are heavier then u will expect, be ready for this and support the axle before pulling the hub or u will deform the axle tube seals. when inserting the axles go slow and dont force them in, have patience or u will screw the seals up like i did......this job will take u 4-6 hrs.
Old Mar 1, 2008 | 10:46 PM
hink's Avatar
Front drive shaft being the key words.
Old Mar 2, 2008 | 08:20 AM
1stdieseldodge's Avatar
also,you will need to replaced the centering ball joint between the 2 joints ,this is tricky when you are trying to install new joints as well,just need a little patience
hawkeye759
14
Dec 27, 2009 11:54 PM
06RAM2500
Oct 1, 2009 01:26 PM
rodriguez7
Dec 30, 2008 11:57 AM
grandblanc
Jun 28, 2008 06:56 AM
BLACKBIRD8200
May 28, 2008 11:12 AM
